Rich, thanks a lot.
The worst of the leaks seem to be coming from the push rod seals. What makes that bad is that it drips right on to the heat exchangers and I'm afraid I'll set the whole thing on fire. Lots of smoke from the exhaust too. But it did run well and accellerate normally. I think that a rebuild is in order as this engine may only have 60K miles on it.
Looked at Jake Raby's site and was pretty impressed. I'll look for Mital. Have you got any feedaback for Import World in CA? They have a bunch of engines, suspiciously cheap.
The closest shop to me is Powertech in Boonton, NJ (Mike Daino) They seem like good guys. Ever dealt with them?
Our biggest problem is time. We have brought this car about as far as we can with the time available, but time is hard to come by. On the time vs money scale, we are shorter of time at the present, and we'd like to get this car done!
Thanks for any suggestions.
QUOTE(r_towle @ Apr 7 2009, 08:20 PM)
When I find these old motors, I typically pull the motor and replace all the seals.
Front and rear main seals.
Push rod tube seals.
Oil pressure sensor
Oil cooler seals
Fuel Injector seals
Valve cover gaskets.
Oil sump gaskets
Oil temp gaskets (if so equipped)
I also remove the head tin and clean all the flamable mouse nests that are in there before they catch fire.
I would suggest that you do a leak down test to see how well it holds a seal...then go from there.
If you want a turn key motor, McMark will do one for you...PM him.
Jake Raby also does turn key motors, but those are bigger.
For local shops, you need to track down Ray Mital..he is around here somewhere and he knows alot of the shops in NJ and NY
Rich
