Im doing an EFI conversion (built 3.0 w/ microsquirt) w/ a 3.2L intake and run into a bit of a question. I bought a cheap 90deg elbow to fit on the TB and it doesn't clear the lid if left in the 'normal' intake tilted away from the fan orientation. I could probably shorten it about an inch, but I still fear a large cone filter will hit the trunk/lid. THouh I guess I could actually cut the elbow at a slight angle making it a little over 90deg and tilting the filter down.
If I flip the intake around, I think a filter will fit fine. I'll have to:
1) rebend the return spring arm up to get the TB to mount (you can see the holes don't quite line up) - no big deal
2) looks like the air bleed adj screw will be pretty difficult to adjust (it gets almost pressed against the shroud.)
3) I'd have to extend the pull linkage & angle a little also.
4) ???
I did a search (note: it seems impossible to search w/ the term '3.2'?) and about the only pic I could find is this one:
It looks like the stock elbow fits fine in the normal orientation. Should I just go w/ one of those and plug the holes in it that I dont need? How is a 3.2 conversion normally done? Though, Im guessing that MOST people w/ 3.2s kept the motronic and thus had to keep the stock elbow and AFM. Im not limited by that.
Has anyone ever flipped one around?
Thanks,
Stephen
