I tried to put my clutch back in today and ran into some problems.
While trying to put the clevis pin back in at the pedal, I found that the years of wear on the clutch pedal shaft built up some metal around the hole, so I can't get the clevis over the pedal.
Is it possible to remove just the clutch pedal shaft, or do I have to remove the entire pedal cluster?
The cluster worked good and everything looks good so I don't think it needs a complete rebuild, just a new clutch pedal shaft
Any thoughts?
