Update 4/17/09
I now have 2 more sets of spacers available and 2 sets of 65mm lugs.
pricing is the same as below. the pictures below are not of the current spacers I have but look the same and are OEM Porsche.
Still have a couple sets of studs in 65mm and 50 mm lenght. 50 mm lenght are for use with 1/4" spacers and the 65mm studs are for use with 3/4" = 21mm spacers.
I have four sets of 21mm spacers and studs from 944 rear wheels.
Spacers are $50 per pair. I have two pair. Only one pair is pictured.
I also have forty 65mm studs which are the correct lenght to use with the spacers.
Studs are $35 for a set of ten.
Shipping is flat rate of $5 for as many studs as will fit in a flat rate envelope.
Shipping for spacers with or without studs is $10.
[s]
