QUOTE(turnaround89 @ Apr 6 2009, 11:38 AM)
I need to lower the front end of my car but the adjusting bolt on both sides is rusted stuck. Ive been spraying liquid wrench to hopefully loosen up some of the rust, i think i might have rounded out the inside of the passenger side because it is stuck. What can i do? can i grind down two sides of the bolt head and get a wrench on it to loosen it up?
Maybe you can just weld a bolt in it which would add some heat as well.
.sounds like its toast anyway
