type47
Apr 8 2009, 12:06 PM
I have a rats nest to sort out and thought it would be useful to be able to look at a wire's color code and find the track and component. Anyone ever made a list? I started a list and made an excel sheet with color/stripe, track(s), and component categories.
dbgriffith75
Apr 8 2009, 12:15 PM
I don't know about a list, but here's a link to a thread that has another link in it for colorized wiring diagrams:
http://www.914world.com/bbs2/index.php?showtopic=74411
VaccaRabite
Apr 8 2009, 12:16 PM
Careful. Lots of wires share the same color. Red, black, brown are all over the place.
Cap'n Krusty
Apr 8 2009, 12:18 PM
You could just refer to the color wiring diagrams in the factory shop manual, and available on the Pelican website and elsewhere. For a REAL MAN, that would be cheating, but I'll never tell.......... Less work, too, I think. The Cap'n
Apr 8 2009, 12:23 PM
QUOTE(type47 @ Apr 8 2009, 11:06 AM)
Readily available, color diagrams were part of the shop manuals.
Pelican Parts has them online here:
http://www.pelicanparts.com/914/914_electrical_diagrams.htm Andy
EDIT: The Cap'n beat me to it ...
type47
Apr 8 2009, 02:43 PM
I have the color wiring diagrams all printed out and grease/oil stained. It's just that when I'm under the dash and come across a "green/white" wire that terminates in a cut end, I'd like to be able to know the track of the current path and the component(s) it connects to so then I can go to the wiring diagram.
jimkelly
Apr 8 2009, 02:47 PM
wires are not only color coded - they are also numbered - look closely
type47
Apr 8 2009, 02:49 PM
Do you mean the gauge number of the wire?
jim_hoyland
Apr 8 2009, 03:05 PM
While on the subject of color coded wire; what sources are there for them, i.e. Black/red Strip, etc ?
Apr 8 2009, 03:41 PM
QUOTE(type47 @ Apr 8 2009, 01:43 PM)
I don't understand what problem you're having ...
The colored factory shop manuals are easy to read and tracing a specific wire to it's source and destination is quick and easy.
Can you elaborate on your actual problem? I'm confuzzled.
Andy
r_towle
Apr 8 2009, 04:19 PM
my issue is that now that I am getting older I cant see anything with my head under the dash and my glasses up on top of the dash...
This just started and its beginning to piss me off.
I get to close and its all a fuzzy mess of crap.
Rich
type47
Apr 8 2009, 08:30 PM
QUOTE(SirAndy @ Apr 8 2009, 02:41 PM)
OK, so it's no real problem, it's just that if I find a wire in the harness I now know the color code of the wire. I'd like to be able to go right to the current track number(s) more quickly rather than look over the whole schematic to find the wire/current track. True that the schematic is only about 110 possible tracks and one could find the track in less than 5 minutes. I am working on a car where the harness has been cut in several places leaving just bare ended wires.
6freak
Apr 9 2009, 07:59 AM
I have a schematics on the complete wiring system that are really big and easy to read and color keyed .but i cant remember who makes them i will have to give you the info Friday
Mike
charliew
Apr 9 2009, 09:09 AM
40 is tough if you haven't needed glasses till then. I once new a real good pool shooter that had a real personality change when he had to adjust to glasses.
please post the source of the big schematics when you find it.
6freak
Apr 9 2009, 03:24 PM
OK ..so i got them from a fella named .
Arthur Zapf...8514 Los Olivos dr... San Gabriel.Ca 91775..Thats what was in the car .Thats all it says on the envelope ..there mite be a web site on the other paper work.I will look tonite
Mike
zonedoubt
Apr 9 2009, 05:45 PM
QUOTE(jim_hoyland @ Apr 8 2009, 02:05 PM)
Any good electrical/electronics supply shop will have colour coded wire.
ScottD914
Apr 9 2009, 07:07 PM
Show us what you've got in Excel. I made this up from my 74 harness after I removed it from the car:
Click to view attachment Hope it's of some use. I'm still on the fence about buying all the wire and making my own harness or working with what I pulled out. Cheers!
JeffBowlsby
Apr 9 2009, 08:38 PM
QUOTE(ScottD914 @ Apr 9 2009, 06:07 PM)
Thanks Scott, really interesting. 45+ some odd wire sizes/color combos, about half are striped. You would need a minimum order of ~500LF of each specially striped wire and standard put up for solid colors is at least 100LF if not 250LF.
Wire prices depend on gauge. If 25 of the wires average $60 each (the striped ones), and the 20 solid colors average $20 each, it would cost about $2000 for one harness, with lots left over, not including the other items needed to duplicate that chassis harness like casing, wire terminals and the dozens maybe a couple hundred hours needed to lay it out and make it just right. Some of the wire terminals are near impossible to find.
I suggest its a better deal to find a good used harness, they can be found cheaply enough and they are not usually worn out like the engine bay harnesses are.
Apr 9 2009, 08:42 PM
QUOTE(Jeff Bowlsby @ Apr 9 2009, 07:38 PM)
I suggest its a better deal to find a good used harness, they can be found cheaply enough ...
A very good condition used, unmolested main car harness can be had for about $200 - $250 these days ...
Andy
type47
Apr 10 2009, 07:56 AM
It's a work in progress.
ScottD914
Apr 11 2009, 08:47 PM
I had found once, a company website that offered all the color combos I needed in all the gauges I needed and they would custom cut to length! Of course I can't find it again, but I'll poke around a bit and post the site if I come across it.
BTW, I like your spread sheet with the current tracks, very handy.
TC 914-8
Apr 11 2009, 11:48 PM
QUOTE(SirAndy @ Apr 8 2009, 11:23 AM)
Thanks Guys,
I have been using the B/W schematic in my book, the color ones are much better. I printed them out for future reference.
