QUOTE(turboman808 @ Apr 14 2009, 11:07 AM)
I would be scared to get near paint with sand paper no matter how fine the grit. I guess you get used to it with alot of practice.
I am wondering if you can get the same effect by using a heavy compound and pad with a machine. Granted it may take longer since you are not taking off as much paint but less likely to cut to deep.
That car is gonna look great when it's done.
You use the sandpaper to flatten the texture and dirt out of the clear and compound to remove the fine scratches by kind of melting it all smooth. A heavy compound on very fresh paint will only slightly soften the worst orange peel, the amount of heat required to melt the texture away would clean wipe the paint off the panel.
Sanding clear is an art and billy that looks damn good, how many cars have you done that to? Did you use a DA for any steps? What compounds are you using?
Cant wait to see it on the ground.
