UPDATE 4/23: Brad was able to help Rob out with everything he needed. Our thanks goes out to him!
Rob is needing some of these items ASAP for his '73 2.0! I hope I typed the list up correctly, but one never knows. I am sure someone will tell me.
We might be able to get some of the items locally, but just in case he wanted to see if anyone on the board had what he is looking for. I am sure we will be adding to the list.
PM or call us at 865-463-2575.
Thanks!
Nel
Heater control cable and lever (no consol style)
4 Oval Copper Gaskets - head to exhaust pipe
4 valve cover gaskets
1 oil filter
1 2.0 air filter
4 grey injector boots
Oil change gaskets
2 2.0 muffler gaskets
8 exhaust stud nuts
4 injector seals - small
2 heater hoses lower and upper
1 mint or NOS drivers side wiper arm
2 wiper blades
4 Spark plugs W7C???
6 muffler bolts, nuts, and washers - (8mm washers and lock washers / 8 mm bolts)
2 white nylon single cable holder (used) for sheet metal
3 black nylon dual cable holder (new only) for sheet metal
Speedo cable
4 CV joint gaskets
