Full Version: Fuel tank sock
silverteener
I had my tank cleaned and sealed but I need to find a new sock to put inside the tank. Are these still around? or is there something else I can use? I searched for one but couldn't find anything on them.
Thanks
roadster fan
Here is the part number: 111 209 147 a
quick search at pelican revealed this $7.95
Pelican Fuel tank strainer 914
Hope this helps,
Jim
tod914
bus boys will have the sock and washer/o-ring thing you need for it, cheap! could try a local vw dealer too now that Jim gave you the part number. http://www.bus-boys.com/fueltanks6879.html
ConeDodger
hcdmueller
I got mine from Bus Depot. The VW ones are a little longer but the important parts are the same.
charliew
longer means more surface filter area.
