QUOTE(SLITS @ Apr 28 2009, 06:39 PM)
QUOTE(McMark @ Apr 28 2009, 03:34 PM)
Early rotors have a different offset. Early rotor only work with early struts and early brake calipers.
You can machine the hub-centric ring off late rotors though.
Or you can machine the early wheels to fit late rotors ..........
What is it, raise the bridge or lower the water?
The answer is this - bogus! So, why not fit a bogus wheel that will work without modification. They're out there. Why try to hide that fact that you aren't original?
The gurus will know. The newbies won't. Wrong!
Pat
