Full Version: Injector numbers
sunfloweryellow914
What is the difference between 031 and 031A green injectors? Can you use both kinds on the same engine?
sunfloweryellow914
Do they have different flow rates?
Part Pricer
I really can't help you with the particular specs on the injectors. There is a big price difference between the two, so I'm sure that it is something significant. What I do know is:
039 906 031 - 1973 and 1974 2.0L engines
039 906 031a - 1975 and 1976 2.0L engines
Dave_Darling
I think the "A" suffix parts are used on 75-76, not 74-75 2.0 cars.
As far as I can tell, there is no difference in electrical resistance or flow rate between the two. Which I am pretty sure means that I simply haven't looked at the right things.
I wouldn't feel bad about using the "wrong" ones, but I would not want to mix and match on the same engine.
--DD
