QUOTE(7275914911 @ May 5 2009, 07:11 PM)
QUOTE(jcd914 @ May 5 2009, 08:22 PM)
Have you looked at the AFM flap? Does it move smoothly? Is the pop off valve in the flap intact and closed?
The flap does move smoothly. Not sure what to look for on the pop off valve.
Have not checked power at pump after it stalls. What would this point to ?
Thanks for all the input.
It could point to the flap not staying open enough to keep the fuel pump powered up. Possibly not enough air flow to keep the flap open at idle.
You could (for testing only) jumper power to the fuel pump and make it run all the time, then see if the engine still dies at idle.
The pop-off valve is a round spring loaded valve (about the size of a quarter) in the AFM flap that pops open if the engine backfires into the intake. The idea is to keep the sudden pressure of a backfire from bending the flap out of shape. Not sure all the AFM had pop-off valves, it took them a while to figure out they needed them on the 914. The low compression of the 1.8 made them very sensitive to vacuum leaks and a small leak could cause them to run lean and backfire.
You need to see that the valve is seated flat in the flap of the AFM and the spring is holding it tight. You have to look from the air filter side of the AFM, may need a mirror and flashlight if the air filter housing is still attached to the AFM.
I notice in a early post you say "Only have plenum to fuel regulator vac line. Mallory D so two on TB are plugged." So what have you done for the Aux Air regulator hose connection and breather hose connection that go to the intake boot between the TB and the AFM?
This is the time in a problem that I back up and start checking things I am sure are OK. You had the complete intake system off and back on when you swapped to carbs. Look back thru all your intake connections. Injector seals in place, manifolds seated to the heads, manifold insulators not cracked, boots from the intake runners to the plenum tight, TB gasket in place, hose routing correct (the diagram, at the pelican link earlier in this thread, is nice). Quickly going back over the basics often uncovers something (often simple) missed.
You might be amazed at what someone on this forum can see in a few pictures of the engine compartment. There has been many a thread here where someone point out a problem just from a picture posted here.
Hang in there
Jim
