QUOTE(type47 @ May 4 2009, 07:44 AM)
EDIT: Upon further research (researching screws and bolts and nuts, too much time on my hands), the following information has contradictions. I thought #9 would be the nuts to the screws but the PET only lists 2 nuts and there are 6 screws so #9 doesn't go. That would mean the #6 is a "sheet metal screw" rather than a machine screw but when I compared the description to the mirror screw (809-00), which I know is a machine screw, the descriptions are the same.
The PET, 807-05, shows 6 each, screws to hold the pocket. Figure 807-05, parts #'s 6, 7 and 9.
#6 900.145.006.02 is a "rais. countersh. h. tap. s." B 3,5 x 19 which I interpret as an oval head machine screw 3.5 mm x 19 mm long.
#7 E 999.591.102.12 is a "protection washer" which is, in American, a finishing washer. The "E" designates NLA
#9 E 999.507.317.02 is a "klips nut lock" possibly a nut for the screw.
Without access to my car, and without clear memory, this is the PET result.
If it were me, I'd go to a hardware store and get the SAE equivalent in stainless steel. A 3,5 x 19 is about a #6 x 3/4".
Beautiful! Thank you for taking the time out to respond with this info. It's very much appreciate!!
