I've enjoyed my 3.0L conversion since 1995 and I now know a great number of 914ers like you who have done the six conversions and are extremely happy with the result.
If you need any of the pieces to do the project, advice or someone to discuss that changing a perfectly good car is a good idea, please email or call. I'll be happy to discuss the process, pros and cons.
Most of you know the items listed and pictured below are the core conversion pieces I can provide to help with your 914-6 conversion project.
1. 914-6 Engine conversion mounts allow you to hang your flat six in the 914-4 chassis. Weather it's a 2.0L a 3.6L or any variation in between, there is a mount kit that will make it fit perfectly. Nearly 1500 of these kits have been successfully used in conversion projects here and in Europe.
The basic kit is $275.00, add the installation hardware for $25.00 and 911 mounts for $60.00 and the kit totals $360.00.
2. The installation also requires a new set of engine sheet metal. This set is a high quality original equipment style steel set and best of all an economical solution to finish off the engine.
The five piece OE style set is $385.00.
3. Accelerator linkage solutions are also available. You will need to change your 914-4 linkage for the 911 engine installation weather it is setup with Carbs., MFI CIS or DME fuel injection. This kit replicates the Porsche approach, is very functional, installs easily and works well.
The basic kit price is $275.00 and the complete DME kit is $350.00.
4. If you don't have a factory 914-6 oil cooler the 911 oil cooler will need a Metric or AN modification to avoid interference with the 914s inner rear trailing arm mount.
The metric modification done on an excahge basis is $175.00. Complete oil coolers are available for $375.00.
5. There are a number of oil supply solutions. I like the stock tank configuration on street and dual purpose cars.
The new Porsche 914-6 oil tanks are $$$. Please contact me for cost details.
Let me know how I can help. Weather it's a component or a complete package. Feel free to email me at a914guy@aol.com or call 214-478-9418 (cell).
I'm Proud To Be A 914 Driver!
