QUOTE(charliew @ May 7 2009, 08:25 AM)
So are you going to use the cowl vent at all? Also is the shifter as good as those on the factory cable shift cars? honda, gm, mr2, so on?
The cableshift is great, only limitation is the 35 year old transmission. Mine has all new syncros and teeth,etc. But obviously its not as much as a gate like the mr2, etc due to the design of the transmission. Take the best shifting with all new bushings that you have stock and maybe a little better than that....
Nope welding the cowl shut in front no fresh air that way.
