How do you set the throttle position sensor? At Idle should the resistance be 1 ohm? or 0 ohm? The article at Pelican I read says to start left screw upper most position and rotate CCW until it reads 0 ohm then move down 1 hash mark and set.. Problem is at upper most has I am already at zero ohms and 1 hash down I am at 0 ohm and actually do not get to 1 ohm until 3rd hash mark so I am lost and any info. would be great as I am trying to troubleshoot another issue..
.. 1974 2.0 stock injection ...
