QUOTE(McMark @ May 6 2009, 07:46 PM)
Only a relatively few engines are set up for mechanical fuel pumps. The boss for the pump is near the flywheel, on the bottom, on the 1 & 2 side. If your case wasn't set up from the factory, you're out of luck.
So if you insist on it, you need to search for a motor that was set up that way at the factory. Then you can build that motor into any displacement/setup you want. Of course, I wouldn't run a 'built' motor on a mechanical setup.
Long story, short: use an electric pump. Especially since the 914 is set up to use one from the factory.
Hey McMark, does that mean the 1.7 I have is worth like....ONE MILLION DOLLARS...
