QUOTE(pktzygt @ May 7 2009, 05:15 AM)
BEFORE: The turn signals would cancell better that my new cars.
NOW: If I turn left, it won't cancel at all. If I turn right, it won't cancel unless I make greater than a 120 degree turn.
I installed a MOMO competition steering wheel. I have yet to connect the horn button. Could this be caused by a improperly installed ring? The wheel seems to be on straight. There is a little bit of up and down play on the steering shaft, not the wheel or adapter. No play left to right. Is there something I could have lost during the install?
I searched, but I was wondering what parts need to be transferred to the MOMO, other than the ring? Any pics of how it should look?
Any Ideas?
Did you transfer the canceling ring?
Is the adapter sitting on the "cclip" if so it's also possible you may need a thin washer too give you a little space...you might be binding.
MOMO adapter for a late 914...part #8082
Turn signal canceling ring with horn contact...113-415-660-A (bug aftermarket part that fits Beetles 71-79, Ghia 71-74, Bus 74-79) This part is a great addition for MOMOs on our cars.
Tips: I used a waver thin washer on top of the cclip that is a stop for the adapter on the steering column. This gave me the little bit more space that I wanted between where the adapter and steering column meet.
For the horn button, I took the large washer that goes under the big steering wheel nut and soldered a ground wire to the washer. Some MOMO horn buttons have one connection while others have two (hot and ground). Eventually I'll put a porsche horn button on (I think) and I'll be setup for both types of horn buttons.
Mark
