QUOTE(Randal @ May 7 2009, 01:08 PM)
You know my trailer came with car tires and to be honest I haven't had any problems with them.
And I'm guessing that they put the car tires on as the trailer as trailer/car combination is not supposed to exceed (something like) 5500#'s. Or it might be 6K.
But wouldn't 6 or 8 ply tires be stronger and less likely to have an issue with the kind of hauling we do?
I know Dan Thompson has had a lot of experience with trailers and such, maybe he will have some opinions?
Randal,
for your trailer I would be using trailer tires (ST) with at least a D load range rating.
I know your 914 does not weigh much, but you do use it for hauling much heavier items from time to time....(how do I know that
) And your trailer is no light weight all my itself...
ST tires are built especially for trailer usage. Stiffer side walls that are less likely to fail from flex etc...
Thanks again for allowing me to use your trailer....it really helped out...
