I have an exhaust leak again. The last time that I removed these, I forgot to get some pics of the bracket on the heat exchangers. Are these original or add ons by the PO? Are these of any value? Could these brackets be putting unnatural stress on the original designed studs - putting pressure on the studs causing a leak? Should I continue to use these brackets or should I just cut em off?
These are from my 73, 2.0, FI engine. Are these HE's from another type of engine? Other than the brackets, the HE's appear to be usual 2.0 HE's.
Thanks.
Warrenoliver
