QUOTE(Jeff Bowlsby @ May 10 2009, 04:12 PM)
You got my interest piqued...does this photo answer it for you?
that's them!! In the upper corners of the cover!! I just had the other one fall out this morning.. Now that I see them I feel better they are not serious.. Thanks Jeff!!
You were dead right on the Tps setting at 1 hash below switch point.. Basically the ECU needs a signal of 1 ohm to suggest idle. I chased that Ohm.. I have tried it at the zero Ohm setting or on the edge which is still O Ohm and the only way it will even hold an idle regularly without the input is to advance the timing on the distributor.. and the richness on the ecu.. ..
Also at the zero mark or switchpoint the calibration setting inside the TPS will allow the ECU will miss 1 trigger point/ pulse (signal) on acceleration richness pulses. stupid demon taught me about the djet dance, I adjusted and readjusted every component checking vacum measurement etc..
1 ohm lesson.. Your FI harness by the way cleared up a bouncy tachmoter.. I should have bought your harness instead of anything first..
