QUOTE(ArtechnikA @ May 11 2009, 03:51 PM)
QUOTE(Randal @ May 11 2009, 06:28 PM)
...fuel injected and brand new, except for a few break in hours on the track, consider buying the motor out of The Beast. It's a 2.7 RS specification.
Hmmmm -- I might be interested in that one...
is that high-butterfly or regular MFI ?
Here are part of the motor specifications:
Built by nationally known Porsche race motor builder Mat Lowrance (Reno).
2.7 Liter 6 cylinder with 9.5:1 compression and Haltech ECU and FI (TWM throttle bodies).
Runs on 92 octane.
Patrick Motorsports lightened flywheel and Centerforce clutch kit.
Rich Johnson center mount 914-6 engine mount.
Smart Racing remote oil cooler filter
Earl fittings used throughout.
Fire shield and/or thermo insulation on all cables or lines.
(available) Intake Silencer with turbo bellmouth for sound restriction tracks.
(available) Exhaust
European Racing Headers 1 ¾” I.D.
(2) Smart Racing products Phase 9 mufflers.
(2) Dynomax Super Turbo mufflers for Laguna Seca sound restrictions
7R case (from a 1974)
oil-bypass mod
time certs on head studs
Mahle Nikasil cylinders
Heads from a 1977 S - 35mm ports
Heads freshly rebuilt by Ted at German Precision
- all new guides, heads flycut, valves ground, seats ground, etc... Solex cams Carerra oil-fed chain tensioners 11-blade fan New-style alternator with new internal voltage regulator Too many new parts to list.
Raceware studs
I have some pictures if you'd like to see them.
