nycchef
May 11 2009, 02:07 PM
wondering how to hook up the breather box. the one i have has 4 ports, i believe the brand is jesse buggy. i know one hose comes off the oil filler. and there are two vents that come off the heads, i have no idea (big suprise there) where they are. need help as usual. pics are always good. thanks
yeahmag
May 11 2009, 03:53 PM
If you are running carbs all 3 of those lines should be run to the breather. I gutted my PCV to get more flow from the filler, but in hind sight I would have made something and kept the original PCV intact for later use. Make sure the breather is as high up in the engine compartment as possible.
lotus_65
May 11 2009, 03:58 PM
As I understand it, the idea is to have the breather box higher than the top of the filler stack. Mine is a CB Performance one that only has 3 tits.
I mounted mine on the trunk wall (most put theirs on the firewall I think). One tit for the filler connection and one each for the heads. I have seen people route to the top of one carb I think to burn the VOC's, but I don't know for sure.
I'll post my pics in a couple hours.
thefleur
May 11 2009, 04:12 PM
QUOTE(nycchef @ May 11 2009, 01:07 PM)
Plug one port. One to each of the heads, one to the oil filler. Mount as high as possible.
Andy
nycchef
May 11 2009, 05:51 PM
Andy
mounted mine up high on the rear trunk wall. i found what appear to be 2 hose fittings on the driver side toward the front, on top of the head and one on the pass side at the rear of the head, plus the oil filler should i use all of them? my box is the same one as in andy's pic.
lotus_65
May 11 2009, 05:56 PM
You might be seeing the FI head temp sender as one of the two on the one head.
don't use that one.
nycchef
May 11 2009, 05:59 PM
QUOTE(lotus_65 @ May 11 2009, 03:56 PM)
don't use that one.
would you know which one it is?
neil30076
May 11 2009, 06:02 PM
QUOTE(nycchef @ May 11 2009, 04:59 PM)
don't use that one.
Rich, see my picture attached - you can see where the breather points are - at least for now - i'm also asking in a thread if these are routed correctly :-)
lotus_65
May 11 2009, 06:05 PM
1, here's your thread,
search king
http://www.914world.com/bbs2/index.php?sho...amp;hl=breatherAnd I guess something's up with the Big Birds 914 diagrams.
I can't recall which is the sender.
thefleur
orange914
May 11 2009, 06:10 PM
QUOTE(nycchef @ May 11 2009, 03:51 PM)
i've seen an unusual nipple on the tin itself before. is that one of driversides?
mike
Cap'n Krusty
May 11 2009, 06:29 PM
Hmmmmmmmmmmmm ............I just answered a similar thread somewhere else. Andy's picture (I know it's not really his, 'cause it's in focus) shows a hookup that's been illegal in 50 states since 1965. You need to run a hose to one air cleaner, and prevent the escape of vapors between the box and its top. The hose fitting for the air cleaner line needs to be on the top of the box. The routing shown in the picture of the engine with the yellow tin shows a closed system, which will cause leaks from everywhere ...............
As for the nipple on the tin, it has to be for the vapor recovery line to the tank.
The Cap'n
nycchef
mike
a pic can explain it better than i can (actually a labrador retriever can explain it better than i can)
orange914
May 11 2009, 06:48 PM
QUOTE(nycchef @ May 11 2009, 04:29 PM)
mike
yep thats the one, it has nothing to do with crankcase pressure it goes directly onto the exposed cylender fins, right? not sure what its used for, maybe some one out there can chime in
nycchef
May 11 2009, 06:49 PM
sorry i posted the pics before i saw the capt"s post. how do i run a line to the air filter it's not enclosed, just a metal plate on top of the paper filter.
i still not getting which is the wrong hose in the pic. does the one going down into the cylinder head go to the breather box?
May 11 2009, 06:56 PM
QUOTE(neil30076 @ May 11 2009, 05:02 PM)
Uhmmm, where is it breathing in your picture?
The way i see it, the heads and the oil filler are all going to try to suck air from each other. Or worse, blow air into each other.
You'll need a opening to the environment somewhere, hence the name "breather".
The CB box, while may appear to be closed, has openings all around the top and a large spunge inside that traps oil vapor.
The oil collected from the heads will drain back into the filler neck on idle or when the motor is shut off ...
Andy
May 11 2009, 07:00 PM
QUOTE(Cap'n Krusty @ May 11 2009, 05:29 PM)
Hey now!
Yes, my picture. And yes, completely illegal. But that wasn't the question, now was it?
Andy
nycchef
May 11 2009, 07:55 PM
better late than never. i think i understand. the nipple coming of the side of the tin is for the charcoal system . i have it hooked up to the oil breather
neil30076
May 12 2009, 09:17 AM
QUOTE(SirAndy @ May 11 2009, 06:00 PM)
Hey now!
Andy
Thanks Andy - carbs on a previously FI 'd car in California are illegal anyway i believe, so one more infraction is probably not going to make much difference
CB part on order today.
Thanks to all for great advice, as always.
Cap'n Krusty
May 12 2009, 09:48 AM
QUOTE(nycchef @ May 11 2009, 06:55 PM)
............which means you're adding air flow IN TO the engine, which needs to get air OUT. The Cap'n
Zundfolge
May 12 2009, 09:54 AM
So aside from legal compliance, is there a performance reason for the breather box and/or dumping the breather lines into the carbs?
My breather hoses just run off to the side and down through hole in the tin dumping down to the ground.
So.Cal.914
May 12 2009, 10:14 AM
QUOTE(Zundfolge @ May 12 2009, 08:54 AM)
Aaaah yessss, BTDT and as it drips at speed it goes all over you tranny/rear suspension and brakes if you plumb it like me. The oil collected in the breather will drain back into the case. A Win Win situation.
nycchef
May 12 2009, 10:35 AM
QUOTE(Cap'n Krusty @ May 12 2009, 07:48 AM)
it has been corrected. goin with andy's illegal set up.they'll never catch me ..
too busy with all the ponzi scemes here. thanks for all the help
tomeric914
May 12 2009, 12:26 PM
Don't use the crappy hoses that come with those breathers. They crack within months of installation and fall apart shortly after. Invest in some good 1/2" hose from your FLAPS.
Also, these breathers are decent for cars that never see any track time. Spend a couple days at the track at high RPM and expect to see a small mess under the breather. Not a dripping mess, but a mess nonetheless.
nycchef
May 12 2009, 12:38 PM
QUOTE(tomeric914 @ May 12 2009, 10:26 AM)
put new hoses all around. my car will never see any track time. it seems to be designed for jack stands
bandjoey
May 12 2009, 09:16 PM
WHAT do you do when there's NOT a port by the manifold in the head for the oil breather hose??
Another place to look or ??? As always, pictures help if you made something else work. Thanks for the additional info.
orange914
May 12 2009, 09:53 PM
QUOTE(bandjoey @ May 12 2009, 07:16 PM)
i've seen a nipple you can add to the valve cover on e-bay or all the heads i've seen have the boss on them that can be drilled to install a nipple. the added nipple to the valve cover can be a pain in the arss i've heard when it comes to valve adjustment.
mike
lotus_65
May 13 2009, 04:48 AM
QUOTE(orange914 @ May 12 2009, 10:53 PM)
mike
yep, there is a boss. i shoulda drilled mine when i had the chance!
i ended up trying to put nipples on the valve covers similar to the ones that came with the cb breather. they where going to interfere with the valve train, so i found some brass elbows and tacked them in.
it's a godawful pita to adjust the valves and they are never completely dry.
just drill the heads.
thefleur
neil30076
May 14 2009, 03:05 PM
QUOTE(SirAndy @ May 11 2009, 03:12 PM)
Andy
Andy, followed your guide, added the CB box and now i can breath again - cheers
Neil
nycchef
May 14 2009, 08:33 PM
Andy
Neil
i.m not looking to stir up any trouble (maybe a little), but now that there seems to be a movement towards andy's breather box setup (i'm a disciple as well), what exactly is illegal about it?
neil30076
May 14 2009, 08:47 PM
QUOTE(nycchef @ May 14 2009, 07:33 PM)
Andy
Neil
Rich, engine fumes get out to the atmosphere, not recycled back in to the air filter and hence into the carbs. You can sort of remedy that by taking the stub on the CB box back into the air filter - not really a legal fix as the box still vents to the outside, but if the car is not subject to state inspection ( prior to 76 is not here in CA, yet!) you can get away with it if an inspector/cop doesn't know what he is looking at!
Neil
ChrisFoley
May 15 2009, 10:50 AM
The Tangerine Breather Kit has an available option for returning the fumes to both air cleaners, and no atmospheric vent.
