heres my question:
the car fires right up, idles great when warm and when cold, BUT... you must physically hold the r.p.m. up to proper rpm. if you open the throttle body screw it will raise BOTH cold and hot rpm won't it? how do you adjust the cold rpm only with out affecting warm rpm? i believe the co/hc mixture is set right throughout rpm range -not to lean or fat-
thanks, mike
