QUOTE(jcambo7 @ May 12 2009, 10:27 AM)
So I can take the cannister off and not have a problem at all...but than what do I do about the openings for the charcoal cannisters hoses that connect to the air intake?
You can. But you will have fuel smell inside the car every time you have more than a 3/4 tank of gas.
- Plug the connection on the air filter and the one on the side of the fan housing.
- Remove the lines behind the rocker.
- Remove the charcoal canister.
- Remove the expansion tank.
- Route the small hose that goes to the expansion tank inside the large plastic overflow hose that goes from the filler neck down and outside the bottom of the car.
- Get used to the smell of gas.
Andy
