If you're going for a temp sender for the factory setup, I don't know, I'm sure SLITS is right.
If I were doing aftermarket CHT, I'd grab one of
These and a couple (If I recall) E type thermocouples to hook up to it. Personally I'd use thermal epoxy to attach the thermocouples to the heads, not a big fan of the under spark plug ones.
I'm partial to the latter because my school has the stuff to weld up thermocouples. Not sure about accuracy, the stock sender is probably a thermistor, these are certainly more durable.
