I just took my 2.o out last month, it had d-jet and put in a 1.8 with l-jet. I swapped them out, to find out i was missing the dual relay and the coil pack.
got the missing pieces and it started right up, but the holes were not in the bay to mount the air cleaner to my 73 year car, no big deal... a bunjee works fine. anyway, the same exaust and heat exchangers bolted right onto it (they were 1.8 anyway) then it ran great for about a week untill...
the wires on the coil pack were so crusty they started popping off one at a time causing a non injectiing fi system. I slapped a new coil pack on today, and its great. Oh, and the ecu does not fit the bracket of the 2.0 ecu, so a few zipties for that and a ziptie for the dual relay.
the only other thing i left out was the charcoal cannistor that sits in the bay, since i had one on top of the fuel tank, i just connected those inline.
the only other thing i did to make sure it lasts the summer is replace the small injector seals and oil filler seals and vacume lines.
Runs like a top, so i can work on rebuilding my 2.0..... bigger
