I know it sounds crazy, but here's the deal: (long story)
A few weeks ago, my muffler hanger broke. I am running a kerry hunter header with a super trapp.
Car starts running like crap. The bouncing of the exhaust has wiggled the header off of the exhaust studs a little and air is getting in there.
Anyway, while I was under there fixing it, I did a valve adjustment. I think I messed up the passenger rear (3?) as I am getting a little popping in the carb on that cylinder. Euro911 and I looked at it and think that intake on that side might be a smidge tight.
Compression test on all cylinders shows them all that same.
I want to adjust just the intake on that cylinder. The KH header is a real pain to do valve adjustments with because I basically have to loosen the driver's side to get the valve cover off.
So is there a way to tell from the passenger side, without seeing the other side, if the intake on 3 is off the cam?
I know the best way to do this is to just do the whole job over, but I am trying to get it running to get to Irvine for C&C Saturday morning. That's about all the time I have available to be a part of the WCR.
Any tips/tricks are appreciated.
