I have a '70 1.7. It has two leaky push rod tubes which I want to fix while I have the HE's off for replacement.
I have just learned that the outer seal (to the head) is smaller than those from '71 on (mine should be 23.5 mm ID, the ones Pelican sells which I have are 25.1 mm ID).
Has anyone figured out a solution? Perhaps some other air cooled VW uses a 23.5 mm O ring?
My leaks seem to be mostly from the inner seal. Is it possible to carefully remove, clean up and reuse the outer seal?
All thoughts as to a solution appreciated.
