OIL DUMP WTF!!!
Factory 2.0 dJet injection. Rebuild by someone else, unknown lineage. I got it from a club member (not a bad on him) Engine has given me 800 trouble free miles to date. No leaks of any sort. New oil cooler seals, new flywheel gasket. No leaks from first 500 miles. then started seeing weeping motor oil where tranny and engine meet. did not smell like tranny fluid. After about 600 miles, oil pressure sensor goes out. replaced, but not tightened correctly the first time. cleaned the seeping oil improperly tightened oil sender and thought nothing of it thinking I had not tighted the sender correctly on intitial install.
Today, I started engine, then steady stream of oil coming down 1/4" diameter from where the engine and tranny mate. I quickly pull it back in to garage. I see oil coming down so I put a drain pan to catch this oil . check dipstick level, its dry. there looks to be the entire engine oil contents on driveway and street.
Do you think its galley plugs or flywheel main seal ? if galley pllugs, can it be repaired with engine in place?
