My engine is an SBC 283 with about 260 Ft-Lb rear-wheel torque and 250 rear-wheel HP (dyno-tested).
I have an oil cooler with fan and an auto thermostat that starts the fan at 180 deg F. The oil cooler is installed on the engine support cross-bar and takes air from below the car and discharges it up into the engine compartment and out through the engine compartment lid. See pictures.
I use the original 914 oil temperature gauge which has no temperature markings on it, but I calibrated it using boiling water and an infrared thermometer. The oil temp sensor is for a Chevy oil pan drain plug. The gauge and sensor happen to work together very well. Straight up is 210 deg F. Mid-left is 160 deg F and mid-right is 260 deg F.
I also have a 7 quart low-profile oil pan. I figure that between the oil pan, the cooler, filter, there are about 9 quarts total. I run 20-50w semi-synthetic.
I find that the oil temperature is very sensitive to air temperature, airflow to the radiator, and engine RPM.
At highway speeds and cool weather (< 70 deg F) water and oil run at 160-180 deg F. Warmer weather or stop/go driving gets the oil to 210 deg F. Hard driving and high revving gets the oil into the 230 to 260 deg F range.
I also did a visual test to find out how much oil gets pumped to the top of the engine, by using a clear plastic tube to see the oil level. There is about 1 quart pumped to the top of the engine and the amount is not very sensitive to engine rpm.
Nick
Click to view attachmentClick to view attachmentClick to view attachment
