Demick
May 18 2009, 04:57 PM
This is the rear transmission cover for a side shift 901 transmission for a 914. Perfect to replace a rear cover with broken mounting struts. Good condition, but one of the muffler hanger studs has been worn down a bit due to a loose bolt (wore some threads off of it). Works fine as-is, but easy enough to replace the stud if you are so inclined. SOLD.
