QUOTE(Jake Raby @ May 18 2009, 08:02 PM)
And wants to use the stock FI CHT position for a gauge, so their CHT values will be 150F LOWER than in reality...
The stock cht is being used for the ecu, i am curious if i could use the #2 cylinder that has the exact hole as my #3 in a guage configuration.. and yes it is probably a 3/4 head in reverse.. I have read that cylinder #3 is key but why? or for a gauge i need to use a sender from sprak plug #3? excuse my ignorance as to proper location for a sender unit/ sensor for a gauge.. this is why i am posting..
all that said what is a good sender unit and where should it be located?? for a gauge..
bascically i am reading the vdo cht senders are crap as they are always off depending on ambient tempature.. as they were created for 72 degress ambient base.. colder you get a hotter reading warmer you get a colder. so if this is true then what if anything is to be used to get a solid reading?
i don't really want an entertainment piece but a true reading..
