No problem with positive and negative if you don't care which direction the pump turns and if you don't care if the pump works after running it backwards and dry.
Look at the pump.
Bosch and all of the others I've seen others have the terminals marked.
Don't run a pump dry, the pump needs gas as a lubricant to prevent damage to the bearings and to the pump rollers and roller contact surfaces.
In the car, gravity primes the pump which is why it's easy to put a pump on a car and fill it with gas before starting it.
On the bench, it's tricky to ensure gas is in the pump before you start. Maybe a hose with a siphon squeezbulb between the gas container and the pump to fill the pump before you start. Squeeze the bulb to fill the pump, start it up. Be sure to have a second container to catch the gas as it dumps out of the primed pump. This also cleans spiders and crap out of the pump.
In our systems, it's the pressure regulator valve downstream from the injectors that can be used as an easy pass/fail tester. Take a known good pressure regulator, attach it to the outlet hose on the PRIMED pump and start the pump. If it's an OK pump, the system will pressurize to an adequate pressure, and the pressure regulator will begin bleeding the excess gas. Make sure the pressure regulator dumps to a catch container.
Be darned careful with whatever you decide to do and do it in an open area away from the house. Gas and sparks are a dangerous mix.
That being said, I'm still amazed that the electrically charged rotors of the Bosch inline pumps actually spin in the gasoline....
