Okay, I think i found the main reason. After being under Lola for awhile trying to remove those stubborn hoses I realized that the shop that did the full tune up put the filter after the pump.
The filter was still dirty but I can only imagine whats inside the pump. Damn it! Cool! Thank you for your knowledge and input. I guess this is the perfect example of why I should do my own tune-ups. I just don't want to but this is a good reason!
One question regarding the later style pump. Which end is the in and out? One port is large and one is small (the small end is between the + & -).Edit: Nevermind, Found a picture at PP.
QUOTE(banger @ May 24 2009, 02:14 PM)
Yes, you can plug the fuel pump return line. This line should "T" with return line to the tank. You could take the T out, so the return goes directly from the pressure regulator to the tank. The early fuel pumps had an over pressure valve, which fed into the return lines. The newer pumps do not have this.
