Hi AGain
The bellcrank system mounts to the rear of the engine. You remove two (large ) bolts (that are already there), mount the bellcrank. thread the bolts back through and tighten.
This is where you get the bellcrank system as shown in post #10 of the other thread, though I do see they are out of stock at the moment.
http://www2.cip1.com/ProductDetails.asp?Pr...129%2D941%2D400 Actualy I just remembered that Chris at Tangerine Racing may have these, maybe Jake Raby also.
You have to find some way of holding the end of the throttle cable and there are not too many places to mount such a thing.
I made a very ugly holder out of square stock and mounted it to the fan housing.
To lenghten the cable, I noted that the end of mine had a threaded end on it. I went to ACE Hardware and bought some brass bits and pieces and some cable.
I drilled and tapped the the brass stock to match the threads on the throttle cable. I fished through some cable into that piece and connected the other end to the new belcrank throttle linkage. Also note, you might need to do something about a return spring also.
Worked like a charm. Though when I finally bring my car in to see the Cap'n in Santa Maria, I fully expect to see him shaking his head when he sees it
I am also told that some throttle cables are longer than others but I have not checked that out.
Bottom line, no matter which throttle linkage you go with, your stuck dealing with provding a mount for the throttle cable.
Check out the guy in the vendor section, he may have that problem solved.
Curt
