I have a 73, 2.0, with FI that has a persistent backfire on deceleration only after the engine has warmed up . I suspected an exhaust leak so I took off both heat exchangers. Both showed leaks at the head/exhaust gasket. I took both gaskets out, cleaned the head where the gasket seats and even tried filing the ends of the heat exchangers themselves so they are flat.
I reinstalled, and it still leaks I then got new gaskets and new 12mm nuts from Pelican (these are the copper colored self locking nuts). The studs seem to be in good shape and are tight. I annealed the new gaskets, carefully inserted them into the heads and reinstalled the heat exchangers. I torqued the nuts to 20 lb/ft. ,started it up and let the engine warm up and then retorqued the nuts. I figured I was good to go. Once it was warmed up, again it backfires on deceleration. WTF?
So, now what? I don't want to keep running it for too long with the exhaust backfire and I am getting damned tired of taking the heat exchangers off and reinstalling.
I am tempted to really crank on those nuts to tighten it down but I know I will snap a stud and then I will really be pissed.
Is there any high temp sealant that will work? Any other ideas?
Warrenoliver
