Full Version: Back Pad mounting
djm914-6
Can someone tell me what screws or bolts are used to mount the back pad to the firewall? I know it was mounted at some point but for the life of me I don't seem to have anything that fits anymore.
I assume these are to be machine screws as it looks like there is a nut behind the tin?? What size and shape do I need to buy?
Thanks.
Oh, there is a larger green and (IIRC) brown wire with female terminals in the tunnel by the interior light wires. Any idea what those are for?
914Sixer
Wires are for the heated back window. They were built into the harness on the -6 but not on the -4. I will have to check the chrome phillips metal screw size.
djm914-6
Thanks for the info. Let me know if you find that screw size so I can pick up a set. I figure I should be able to get something at Lowes if all else fails.
