Yaa.... so what does that equal in lbs?
When I did the conversion I must have screwed something up, I came up with springs in the 500lb range????
KP*8.91=newtons (something odd like that???)
Anyways.....read my 1st response Andrew....unless the springs are
factory these numbers don't mean a thing...even if they are factory, I'm pretty sure Porsche did not equip our cars with 140 lb springs
There is no "standard" amongst spring manufactures on what color spring/dot/line or whatever marking is stamped.
Measure the springs, it's the only 100% proven method of knowing what rate they are.
