6freak
Jun 1 2009, 09:13 AM
Will the lower control arm? trailing arm? off that scrape car im parting work (after rebuild of course) on my factory-6 ? so i can send them off have them rebuild and just pull the old one out and slap the rebuilds in ......Scrape car is a early1974 - 4 and mine is a 1970-6....Thanks for any help
Mike
Lavanaut
Jun 1 2009, 09:18 AM
QUOTE(6freak @ Jun 1 2009, 08:13 AM)
Mike
Wrong forum Mike, but I believe the answer is "yes".
Reid
6freak
Jun 1 2009, 09:33 AM
QUOTE(Lavanaut @ Jun 1 2009, 08:18 AM)
Mike
Reid
Sorry i didnt think about that part
Gint
Jun 1 2009, 12:04 PM
If you're talking about the control arms (I can't really tell what you're talking about for sure), I thought there was at least one subtle difference in the 6 and 4 control arms. CRS won't allow me to recall exactly what it is though.
Anybody? Moved to the garage.
jt914-6
Jun 1 2009, 12:36 PM
To use the lower control arms on the '70 you'll have to use the '70 ball joint. They are different between the '70 & '74.
Lavanaut
Jun 1 2009, 12:49 PM
Mike, out of curiosity, what is there to rebuild as far as a trailing arm goes? New bushings?
Randal
Jun 1 2009, 01:01 PM
If you are talking about the rear trailing arms suggest you look at Chris Foley's stuff at:
http://www.tangerineracing.com/suspension....Trailing%20ArmsHe is an advertiser here, a poster here and does excellant work.
He did the total trick on my trailing arms and they came back straight and totally reinforced.
Really nice work.
Richard Casto
Jun 1 2009, 01:20 PM
torsion bar spline count on the 914/4 is different than 911. So if you mix and match 914/4 with 911 you must use a torsion bar that is made for that arm (spline count). I can't remember if spline count for the 914/6 matches the 914/4 or the 911. PET diagram should show if the 914/6 part is the same as the 911 part.
6freak
Jun 1 2009, 01:21 PM
QUOTE(Randal @ Jun 1 2009, 12:01 PM)
Really nice work.
yup thats what im talk`n bout .. but with out the stiffning and will the two interchange from 4 to 6 cars Maybe i`ll just give him a ring Im sure he will know..Thanks to everyone for the help
Mike
Richard Casto
Jun 1 2009, 01:22 PM
It is confusing as to what the OP is asking. Are we talking about front suspension (a-arm) or rear suspension (trailing arm)?
6freak
Jun 1 2009, 01:37 PM
QUOTE(Richard Casto @ Jun 1 2009, 12:22 PM)
Trailing arm ....just could remember what its called ..Im on the right road now
Gint
Jun 1 2009, 03:27 PM
It's also confusing because 914 rear trailing arms are also control arms.
Like I said before, I'm pretty sure there is a subtle difference between 4 and 6 trailing arms. I think it's the e-brake mount, but I'm not 100% certain.
6freak
Jun 1 2009, 03:34 PM
QUOTE(Gint @ Jun 1 2009, 02:27 PM)
so i was right
that dont happen to much..LOL
Gint
Jun 1 2009, 03:43 PM
Where's that shea-guy
Click to view attachment when you need him?
6freak
Jun 1 2009, 03:47 PM
QUOTE(Gint @ Jun 1 2009, 02:43 PM)
4 real`s
ChrisFoley
Jun 1 2009, 09:25 PM
The arms themselves are the same.
Differences were in bolt-on components:
the brake calipers - sixes have bigger pistons;
the hubs/rotors - sixes have 5 lugs, not 4 bolts.
BTW, the stiffening on my refurbished trailing arms is lightweight and comes at no extra charge along with the straightening, powdercoating, new bearings, new bushings, and new pivot shafts.
Larry.Hubby
Jun 1 2009, 09:52 PM
I believe the trailing arms are the same on the 914 for all years and models (there are, of course, different left side and right side parts). At least, PET shows the same part numbers for the left and right arms of all years and models.
JRust
Jun 1 2009, 10:59 PM
QUOTE(6freak @ Jun 1 2009, 02:47 PM)
4 real`s
Mike I think you should get them done no matter what. I know if they didn't work for you? I could get them from you cheap later
6freak
Jun 2 2009, 09:06 AM
QUOTE(JRust @ Jun 1 2009, 09:59 PM)
4 real`s
fur sure buddy ..I was just hope`n to get a set rebuilt so the car wont sit to long..kind of a pull the parts and put the new one`s in the same day..If she sits on the JS`s too long she gets an attitude
6freak
Jun 2 2009, 09:16 AM
QUOTE(Racer Chris @ Jun 1 2009, 08:25 PM)
Hello Chris! so your saying that I can take the set off the four banger have them rebuilt and then just bolt it up to my 6 and everything else will bolt right on...I dont want the stiffening part just the powdercoat, bearings , bushings and shafts..and zerks ..I will give you a call soon thanks
Mike Crandall
JFJ914
Jun 2 2009, 10:02 AM
QUOTE(6freak @ Jun 2 2009, 11:16 AM)
Mike Crandall
The rear brake hose hole on the -6 and early -4 are smaller and use a 911 hose and mounting hardware. the 74 uses a vw hose and vw mounting hardware. Both are the same at the body. One of the -6 arms has a bracket on it to support one of the oil hoses. Get the -6's rebuilt and keep it original.
6freak
Jun 3 2009, 01:24 PM
I was just kinda look`n for a quike turn around .In and out of the shop .I will have to be one of the winter projects if i keep it all real ...but thats ok to. it give me something to look forward to this winter and while its on JS i will do the front as well
McMark
Jun 3 2009, 01:34 PM
Late 914 trailing arms have a slot in the brake line bracket to allow the brake system to be separated from the tailing arm without cracking open the lines. Early 914 arms (including 914/6) have a brake line bracket that is completely circular, so in order to remove the trailing arm, you have to crack open the brake system.
They are interchangeable and I'd bet money that even the most thorough concours will not pick up on that subtlety.
Eric_Shea
Jun 3 2009, 07:58 PM
Early 4 and 6 are the same:
-Round hole brake line as Mark mentions
-Extra tab welded on to accomodate the -6 flapper box cable.
Late 4 are slightly different:
-Slot line holder as Mark mentions
-No extra tab for -6 stuff
Search is your friend. I've posted pictures of the differences in the past. I have a pair of each in stock and powdercoated, ready for fresh bearings.
6freak
Jun 3 2009, 11:31 PM
QUOTE(Eric_Shea @ Jun 3 2009, 06:58 PM)
OK sounds like i have the answer i need ...Now who`s gonna give me the best price? or maybe do some horse trading...I have complete suspention under a early 74 ID stamped 12-73 it all there except right rear caliper..just send me a PM if interested...Hope i`m not breaking any rules! Asking about trading and all Thanks to all that replied
Mike Crandall
