QUOTE(Jeffs9146 @ Mar 3 2004, 01:58 PM)
You will also need to have spacers made to move the rotor out into the center of the caliper (about 5mm).
...what do the spacers look like and where do they go? It looks like if you just put the spacers in the calipers it will bring the outside edge out to match the thicker rotor.
well, that's the way it looks at first blush, the the spacer is referenced to the center of the disk even though it mounts the same old place...
i've seen people who have done it (somehow) by mounting the calipers farther inboard but it looked to me like there's not enough room and the calipers will hit the trailing arm. when i did this done (i donno where the spacers came from, i think they were custom in those days) i spaced the disk outboard.
3mm (standard 1/8" aluminum sheet) is enough. it looke just like a really skinny wheel spacer - 5x130 holes for the lugs, big around as the hub. slide in on the hub, slide on the disk, ta da.
it also give you that smug satisfaction that you have increased your rear track 1/4" and nobody can tell by looking :-) ...
