r_towle
Jun 7 2009, 04:30 PM
SO,
Where can I buy wire that is the right color....
I am planning to remove the FI wiring harness and store that...just so when I change my mind its simpler to go back..
Now, I want to build a new harness for the coil/tach and heater fan...
Oil pressure sender, etc.
I want to use the right color wire if possible...but I can live it I cant find it easily.
I DO NOT want to use old wiring...though I have several harness's, I want to stay away from the old wires...they are part of the problem.
Rich
dbgriffith75
Jun 7 2009, 05:18 PM
I've never tried it but maybe you can go to an auto parts store or electrical supplier and special order it?
Katmanken
Jun 7 2009, 06:11 PM
Buy wire in the right basic colors of insulation and a BIG box of colored sharpies to make the stripes....
Phoenix-MN
Jun 7 2009, 06:34 PM
DigiKey has a good selection but not all colors to match the stock harness.
http://search.digikey.com/scripts/DkSearch...p;keywords=wire
craig3x
Jun 7 2009, 06:35 PM
Try Fry's electronics. They seem to have everything
championgt1
Jun 7 2009, 08:09 PM
Might want to check this place out.
http://www.alphawire.com/index.cfm
banger
Jun 8 2009, 01:18 AM
Waytek wire has a large selection of automotive wire and accessories, fuse holders etc.
Waytek Wire
brownaar
Jun 9 2009, 07:01 PM
I've ordered from these guys. They have wire and alot of the hard to find connectors.
Eagle Day
Dr Evil
Jun 9 2009, 09:00 PM
If I could find a supplier for correct colors I would consider making new wiring harnesses
r_towle
Jun 9 2009, 09:04 PM
QUOTE(Dr Evil @ Jun 9 2009, 11:00 PM)
I was actually thinking of a plug and play carb harness....
Simple and it plugs into the relay board.
Rich
sixerdon
Jun 9 2009, 09:30 PM
Rich,
Why don't you contact Rhode Island Wiring Service? Aren't you a member of typ356ne? They had a tech session there in late March. Look them up.
Don
rudedude
Jun 10 2009, 11:04 AM
Waytak has heat shrink tubing that very closely matches original if that is a concern.
