QUOTE(Cap'n Krusty @ Jun 8 2009, 12:08 PM)
That's not a part number. The number is stamped into the metal, not printed on the ceramic. You should be using NGK B6ES (7432) or Bosch W7CC (7998). With carbs, you should probably run one heat range hotter. The Cap'n
Hello Cap'n , I have the 72, 914 with the 1.7 eng. and dual webers. you suggested the hotter plug W8CC - 7904 I am having a heck of a time finding here in IL. tried NAPA , Autozone etc. is that a Bosch plug? any suggestions or websit to find that plug ? Thanks Dan
