I bought a 914 a few months ago and went to do a valve adjustment recently since the engine was a little noisy for my taste. Well all the valves are set at .006 but I still had my doubts so I removed one pushrod from each side and had a look inside and sure enough, I have hydraulic lifters. Lovely!!! I guess the previous owner was adjusting them as solids. I also have solid pushrods. WTF!! Even lovelier!!!
I know I need to switch back to hydraulic pushrods but I am interested in knowing if theres a difference in the expansion rate of solid and hydro pushrods? I've put well over 2k miles on this engine with no problems and it runs hard, just a bit noisy is all. The valve lash has been set at .006 for the last 8 years the previous owner had it and l am thinking the lifters might be damaged also from being run this way?
