QUOTE(Pat Garvey @ Jun 23 2009, 09:11 PM)
I find myself humbled!
How do you get the wires out of the side marker boot(SMB) without destroying the boot, which is just fine?
I've been going in from the top (turn signal assy removed). Now, can you put enough "juice" on the SMB to extract the wires & connectorrs without destroying the boot? Can you do it one at a time?
I don't want to snip the wires & get a new boot if I don't have to.
What'd you do JB.
Pat
Sorry to take so long to get back to you Pat, PC blew up again.
This is a new one I just built; $
I took everything apart, cleaned & replaced all sorts of rubber George should have replaced 6 yrs ago.
My old boots & backs of my TS assemblies were covered in 35 yrs old undercoating. When I did this the car was up on jacks, assy. removed, wheel off, I came in from the wheel well & daylight was shining through the holes for the turn signals. Old rubber was so ugly w/ undercoating it would have destroyed them to clean so I just cut them off & replaced w/ new ones from George. I did not snip the wires, I snipped the rubber boots. After cleaning the wires I found it beyond difficult to put it back together w/out lube & I wanted a lube I know evaporates & goes away, hence the armorall. Wiped them clean & masked them up so I could apply new undercoating, properly. As you know, my Dad's car was undercoated @ the dealer so concours-wise the car should match the paperwork. After the stuff was dry I put the signals & wires back, all clean & shiny w/ no overspray & new boots all around. I re-crimped the spade connectors for strength, sprayed the rubber w/ the "magic liquid", shoved the spades into their respective holes & fished them out using needle nose pliers. Most importantly I did one side @ a time so I would not have to bother w/ remembering or marking which wire went where...
PS- "armour all" was meant to get your attention & obviously it did
