degreeoff
Jun 9 2009, 05:18 PM
OK here is the deal.
You all know the car smokes and my attempts at diagnosing the issue have showed cold leakdown of about 13% + or -. I believe there is a ring seating issue as well as a valve guide issue though not terrible but DAMN when I lay on the gas @ a stop light or off the line it will puff a bigun! It runs and good at that! Still pulles like a banchie and was will be a top contender @ atouX's and such.
I could leave it out and fix it
to the tune of $700 to $2000 which I cannot afford right now. AKA 4+ months minimum OR I can put it back in and run it as is and wait for the winfall (Great aunts estate) to settle which ata a best guess will be between 7 months to a year from now and repair the issue then. Will it last? I know the guides are not THAT bad.......
What would you do?
Zundfolge
Jun 9 2009, 05:21 PM
If its not your daily driver, I'd just wait until the money comes in.
degreeoff
how do I turn this into a poll?
r_towle
Jun 9 2009, 05:22 PM
Its a toy.
Run it till you can do it right...drive something else for your DD...
RIch
lotus_65
Jun 9 2009, 05:23 PM
QUOTE(r_towle @ Jun 9 2009, 06:22 PM)
Its a toy.
RIch
VaccaRabite
Jun 9 2009, 05:24 PM
Toss that 2.5 you have built into it.
Zach
degreeoff
Jun 9 2009, 05:25 PM
hell ya its a toy I drive it every now and then.....
r_towle
Jun 9 2009, 05:27 PM
ok, so it burns oil...big deal.
It will get worse, yup.
If you hear noises, its time to pull it our for good.
I suspect your pricing guess is not right. You need new guides and new rings and re-honing of your cylinders...
All that work has to be subcontracted to others...
Rich
PanelBilly
Jun 9 2009, 05:30 PM
Drive it the way it is.
banger
Jun 10 2009, 12:48 AM
Do you know if the piston ring end gaps are correct? This could cause a little more oil to seep by, and cause some of the leakdown problems.
IronHillRestorations
Jun 10 2009, 07:14 PM
Run it til it breaks, or you run out of things to do.
Dr Evil
Jun 10 2009, 09:47 PM
Drive it and take a Midol for any side effects you may be experiencing
PM me and I can put you in touch with a shop that does good work for good prices.
charliew
Jun 10 2009, 11:16 PM
Trade it in on a boxter that doesn't smoke when you get rich.
degreeoff
Jun 10 2009, 11:34 PM
too late shes coming apart! on the engine stand now. Its an easy fix I believe....found a local shop to give the heads a look and we'll go from there!
a boxter??? you f'n kidding me? I'd sooner sell/trade a nut than this car! Its a cayman/boxter/911 eater! and fun as hell!
Dr Evil
Jun 11 2009, 12:07 AM
Well, there goes your driving season
degreeoff
Jun 11 2009, 07:14 AM
Nah mike,
I'll have it back together in a month....its called OCD !!
