QUOTE(r_towle @ Jun 9 2009, 06:27 PM)
QUOTE(nycchef @ Jun 9 2009, 10:24 PM)
i kmow it never ends with me. but i have to tune my car and need a dwell meter and a timing light. is this one better than buying 2 seperate devices?
http://www.sears.com/shc/s/p_10153_12605_0...rd=timing+lightThat is a timing light for a distributorless ignition.
Its not a dwell meter.
Rich
rich are you sure look at the description it even comes gift wrapped
Description
Professional-grade, easy-to-use tune-up tool. View and adjust base timing and overall ignition advance on Conventional and DIS (Distributorless) 2 and 4-cycle ignition systems. Slim rotating barrel for compact spaces with optically-tuned lens for a clear, bright flash. Digital readout displays RPM, Ignition Advance, Battery/Alternator Voltage and Dwell readings. Serviceable Leads include Metal pickup which withstands heat, fits 10 mm ignition wires and uses heavy-duty battery and Dwell clamps. Plastic storage case. Will be $159.99 in '09 Annual Catalog. Wt. 3.6 lbs. Catalog/Online Exclusive
This product is: Available for Gift Wrap
