Ray Warren
Mar 4 2004, 07:47 AM
My alternator light is on bright all the time.
The only time it changes is when it is at idle,
it flickers dim.
As soon as i give it some gas it goes bright.
I have changed the VR but it still does the same
thing. The volt gauge is reading about 12v and
moves up slightly when i give it gas.Belt is tight.
I have read the tech article on PP but not sure what to do.
Any thoughts or suggestions?
Joe Bob
Mar 4 2004, 09:27 AM
Get a multimeter. Check battery with engine off, should be 12.5+ volts.
Engine at idle 13+, 2500 rpms, 13.5-14 volts. Any more than that it prolly the regulator. If under 13v looks as if the alt is toast.
tesserra
Mar 4 2004, 11:00 AM
I know this sounds wierd but when I bought my first 76 2.0 from a "donate your car" place the alt light was on. I got it home and started fixing stuff. Replaced non functioning brake bulbs and the light went off. I could not believe it so I traded them back and the alt light went on again.
It never had a charging problem in my three years of ownership.
I have never found anybody that has had this symptom on there car. This was a VERY clean and unmolested '76 with no wiring work done and all electrics worked great.
Good luck,
George
rhodyguy
Mar 4 2004, 11:01 AM
check the fan belt, then proceed. #1 in the fault diagnosis p.142 in the haynes. when i was dealing with no light, #2 was "bulb requires replacement". right below "battery flat or defective".
kevin
RocknRollFrenzy
Mar 4 2004, 12:43 PM
sounds exactly like what my light was doing when my alternator fried. probably not what you want to hear, i'm sure.
tat2dphreak
Mar 4 2004, 12:46 PM
mine was doing it with a bad blinker light too...
rhodyguy
Mar 4 2004, 01:02 PM
think anybody ever got burned for a new alt and ?hrs labor by a repair shop when it only the bulb? <_<
kevin
tat2dphreak
Mar 4 2004, 02:22 PM
probably... that's why something simple like an alt. swap should be DIY...
Ray Warren
Mar 4 2004, 07:15 PM
QUOTE(mikez @ Mar 4 2004, 10:27 AM)
I tried this quick test tonight
not running 12.65 volts
at idle 13.4
2000 rpm 13.4
all bulbs are working.
Joe Bob
Mar 4 2004, 07:19 PM
Sounds like almost dead...but not mostly dead.....it's on the way.
Bet if the headlights were on you would get 12v or less....if not now, but soon.
