ynotdd
Mar 4 2004, 01:12 PM
I am going to put a in line fuel gauge in.I am thinking of putting it near the adjustable fuel pressure unit.(stock FI) my question is what size is the fuel line there? I.D. ?Summit sells 1/2 and 3/8 fittings
help and thoughts please
steve@ottosvenice.com
Mar 4 2004, 01:17 PM
8 mm Fuel line is used there. Steve
ynotdd
Mar 4 2004, 01:23 PM
what does 8mm translate to 1/2 5/16 3/8 ?
JWest
Mar 4 2004, 01:24 PM
Very close to 5/16".
rhodyguy
Mar 4 2004, 01:38 PM
get metric.
kevin
Chris H.
Mar 4 2004, 01:44 PM
Dave_Darling
Mar 4 2004, 02:10 PM
The fittings, last I measured, were 7mm. I think 8mm would be a bit of a loose fit... I don't think metric fittings are necessary, particularly if you get barbed fittings. Which I would recommend. Do use the FI-style hose clamps, not the "regular" ones that slice up the hose as you crank them down.
--DD
tod914
Mar 5 2004, 02:08 AM
7mm is a really really tight fit. That is what came stock on the car. 8mm fits nice. Much easier to get on and off. Try a local VW parts vendor or Foriegn supply place. Most will sell it. Make sure it is braided high pressure line.
lapuwali
Mar 5 2004, 09:28 AM
5/16" is only 0.002" smaller than 8mm, and a lot easier to find in the US. I'd venture that the manufacturing tolerances for fuel hose and barbed fittings are no better than 0.005", so they're basically the same. Indeed, I'd bet there's one factory making fuel hose that marks half the batch as 8mm, and the other half as 5/16".
