QUOTE(EJP914 @ Jun 14 2009, 11:09 AM)
QUOTE(9146986 @ Jun 14 2009, 11:47 AM)
If it was a good/correct compression check, then you have problems. 50 psi difference is way out of range. That may not be causing your backfire problem though. I'm going to guess the vacuum advance on the distributor could be sticking.
I thought it might be exhaust leak too, but I checked the connection of the exhaust at the heads and all seem to be tight. No black soot on the surface of any of them.
If vac advance is sticking, is there some way to un-stick it?
Before I'd do anything else I think I'd look at the exhaust flanges and ports very closely. Be sure to use a flashlight and look for soot. Wipe a finger around the exhaust pipes right at the flanges, both at the head and at the muffler.
As far as the distributor advance, I check it with a Mitivac, which is one of those hand operated vacuum pumps. You can take off the distributor cap, and then pull vacuum on the dashpot and make sure it moves smoothly. Alternately, you can just pull the distributor, clean it up and lubricate the advance mechanism.
